pralhad
Dec 10, 2020Aspirant
Two XS712Tv2 switches need configuration for contineous connectivity if any one fails
We want an on site engineer to install and configure the managed swithes with port stacking.
schumaku
Dec 11, 2020Guru - Experienced User
Is this about two XS712Tv2 as indicated?
Where are you located?
What is the environment where some kind of HA configuration is required?
pralhad
Dec 11, 2020Aspirant
We are located in the Country : India State : Karnataka City : Belgaum
- schumakuDec 12, 2020Guru - Experienced User
If the idea is to configure a LAG with port members on multiple stack units (so called MLAG) - the XS712Tv2 (or any other Smart Manged plus XS model) is not stackable, there is no way to configure MLAG spanning multiple devices.
