mikeymikemik3's avatar
Feb 17, 2022
Orbi RBS350 Continously Blinks White
After moving locations, one of my satellites stopped working and the Orbi app is unable to identify it.
I already tried doing a hard reset and its just continously blinks white.
The firmware version is also updated (V4.4.0.10)
I tried contacting support as the product is still under warranty. But my request was ignored and closed even after I provided sufficient details.
Has anybody faced any similar issues?
  • Is 3 meters enough distance? I've pressed on the sync button and its blinking white for quite a long time now
    • mikeymikemik3's avatar
      mikeymikemik3
      Tutor
      I literally placed the satellite almost right next to the router. The RBS does NOT appear in the RBRs web page at all.
      • FURRYe38's avatar
        Try at least 10 feet away from the RBR. Next to the RBR is too close.
        Is a prior RBS entry on the RBRs web page exist or nothing is seen here?
        Press the sync button on the RBS then on the RBR and let it sync.
