versatiletech
Dec 05, 2016Tutor
Unable to take configuation backup
Hi, I had GS108T managed switch. I had an issue when i'm taking the backup of configuation. As per the documentation 1) Click the maintenance tab. There i'm getting options for ( Upload, downloa...
- Dec 11, 2016
Hi versatiletech,
I just want to follow-up on this. Were you able to setup a TFTP server on your PC then downloaded the text configuration file?
DaneA
NETGEAR Community Team
DaneA
Dec 05, 2016NETGEAR Employee Retired
Hi versatiletech,
Welcome to the community! :)
On the web-GUI of the GS108T switch, when you go to Maintenance > Upload > File Upload, on the File Type field, select Text Configuration. Kindly read pages 7-4 to 7-5 of the GS108Tv2 user manual here as reference.
DaneA
