versatiletech
Dec 05, 2016Tutor
Unable to take configuation backup
Hi, I had GS108T managed switch. I had an issue when i'm taking the backup of configuation. As per the documentation 1) Click the maintenance tab. There i'm getting options for ( Upload, downloa...
- Dec 11, 2016
Hi versatiletech,
I just want to follow-up on this. Were you able to setup a TFTP server on your PC then downloaded the text configuration file?
DaneA
NETGEAR Community Team
DaneA
Dec 05, 2016NETGEAR Employee Retired
Hi versatiletech,
Welcome to the community! :)
On the web-GUI of the GS108T switch, when you go to Maintenance > Upload > File Upload, on the File Type field, select Text Configuration. Kindly read pages 7-4 to 7-5 of the GS108Tv2 user manual here as reference.
DaneA
versatiletech
Dec 05, 2016Tutor
Thanks,
I had done the same. But There is another option with transfer mode. Only option highlighted was TFTP. I'm attaching the reference screenshot.
- DaneADec 06, 2016NETGEAR Employee Retired
Hi versatiletech,
I understand that TFTP is the only option. You will need to setup a TFTP server on your PC for you to download the text configuration file. Kindly browse the links below that I have found online on how to setup a TFTP server:
How to setup a TFTP Server using tftpd32 in Windows
Setting up your local machine as a TFTP server
You may want also to check on YouTube for video turorials on how to setup a TFTP server.
DaneA
- versatiletechDec 06, 2016Tutor
Thanks will be checking.
- DaneADec 11, 2016NETGEAR Employee Retired
Hi versatiletech,
DaneA
