versatiletech
Dec 05, 2016Tutor
Unable to take configuation backup
Hi, I had GS108T managed switch. I had an issue when i'm taking the backup of configuation. As per the documentation 1) Click the maintenance tab. There i'm getting options for ( Upload, downloa...
- Dec 11, 2016
Hi versatiletech,
I just want to follow-up on this. Were you able to setup a TFTP server on your PC then downloaded the text configuration file?
DaneA
NETGEAR Community Team
versatiletech
Dec 05, 2016Tutor
Thanks,
I had done the same. But There is another option with transfer mode. Only option highlighted was TFTP. I'm attaching the reference screenshot.
DaneA
Dec 06, 2016NETGEAR Employee Retired
Hi versatiletech,
I understand that TFTP is the only option. You will need to setup a TFTP server on your PC for you to download the text configuration file. Kindly browse the links below that I have found online on how to setup a TFTP server:
How to setup a TFTP Server using tftpd32 in Windows
Setting up your local machine as a TFTP server
You may want also to check on YouTube for video turorials on how to setup a TFTP server.
DaneA
- versatiletechDec 06, 2016Tutor
Thanks will be checking.
- DaneADec 11, 2016NETGEAR Employee Retired
Hi versatiletech,
DaneA
- DaneADec 14, 2016NETGEAR Employee Retired
We’d greatly appreciate hearing your feedback letting us know if the information I’ve provided has helped resolve your concern or if you need further assistance.
If ever your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
