versatiletech
Dec 05, 2016Tutor
Unable to take configuation backup
Hi, I had GS108T managed switch. I had an issue when i'm taking the backup of configuation. As per the documentation 1) Click the maintenance tab. There i'm getting options for ( Upload, downloa...
- Dec 11, 2016
Hi versatiletech,
I just want to follow-up on this. Were you able to setup a TFTP server on your PC then downloaded the text configuration file?
DaneA
NETGEAR Community Team
Tayyan
Jul 22, 2017Aspirant
Hello,
I have tried to setup Tftp Server but it seems there is an issue with assigning the File path on the netgear web interface, I keep getting this error message when I click on the apply:( Error! File path cannot include the symbols:':*?"<>|' and maximum length is 160.)
the file path that I choose was : (C:\fttp) and its the same chosen path on my Tftp settings.
Tayyan
