versatiletech
Dec 05, 2016Tutor
Unable to take configuation backup
Hi, I had GS108T managed switch. I had an issue when i'm taking the backup of configuation. As per the documentation 1) Click the maintenance tab. There i'm getting options for ( Upload, downloa...
- Dec 11, 2016
Hi versatiletech,
I just want to follow-up on this. Were you able to setup a TFTP server on your PC then downloaded the text configuration file?
DaneA
NETGEAR Community Team
Tayyan
Jul 22, 2017Aspirant
Hello,
Problem solved, I only need to put the dash mark (/) in the Transfer file path on the Netgear web interface and it worked.
But i have one question:
Is the configuration backup that’s done on the SmartControlCenter is the same file type as backup file that is created using the web Browser interface (Text Configurations)?
I ask that because the file that I get from the TFTP server is File type and the file that I get from the Smart Control Center is CFG File and I need to know file type that I get from using the TFTP server Text Configurations So i can Change it to the right type.
And thanks in Advance
Tayyan
