egonbar
Jan 18, 2022Aspirant
Understanding the Timer Schedule on a GS324TPP
Hello
When i configure the timer schedule like "periodic" the switch change it to "absolut".
I have read it
and i update to firmware GS324Tx-v1.0.0.38 but it happen the same.
Some ideas to solve it?
Thank you
1 Reply
- DaneANETGEAR Employee Retired
I believe you are referring to GS324TP and not GS324TPP. It is because there is no GS324TPP switch model.
Was the timer schedule working fine before? As far as I have checked, there is no issue logged like what you have described here on your post for the GS324TP regarding the timer schedule. I suggest that you open a support ticket with NETGEAR Support here at anytime for further investigation and hardware check.
DaneA
NETGEAR Community Team
