karljw's avatar
karljw
Follower
Jan 04, 2022
VALN configuration to route to multiple subnets from XS708T to XS728T
Hello all.
I have a network without DHCP. There is no router and all switches in the environment are xs708t or xs728t.
Each switch has its own subnet:
Switch A: 192.168.0.0/24
Switch B: 192.168.10.0/24
Switch C: 192.168.20.0/24
Since there is no layer 3 routing capabilites I need to use vlans (layer 2) to pass this traffic. I have attempted configuration of the vlans by  assigning ips on each for the neighbor subnet I want to trunk traffic to. I do not want segregation of vlans as I would like to be able to log into any device from anywhere on the network. I am only using the vlan infrastructure to pass the subnet traffic.
I used this doc combined with the switch manual to set up the vlans, but cannot pass traffic between them to neighboring subnets:
https://kb.netgear.com/11673/How-do-I-setup-a-VLAN-trunk-link-between-two-NETGEAR-switches
Can someone advise on how I can get this to work?
Thanks,
-k
1 Reply
  • schumaku's avatar
    schumaku
    So what now - three VLANs makes three dedicated networks, however you aparently seek one flat network (no seggregation) with three IP subnets?
    You can't magically keep one IP subnet on a switch each of connecting these direct, without any routing.
    Such a config does not make any sense - three IP subnetwork on one network is a recepie for another nightmare.
    Back to the drawing board.
    PS. Have requested a moderator to move to the Smart Managed Plus section - no managed switches involved here.
ProSupport for Business
