Aljst
Nov 15, 2016Aspirant
Very hard to contact support
When I buy an Enterprise Class product, I expect to be able to speak to support in a reasonable amount of time without endless phone loops and hurdles to surpass. In an Enterprise your product eithe...
- Nov 21, 2016
Hi Aljst,
Thank you for the follow up. Hopefully, the replacement unit will serve you well. If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
Aljst
Thank you fro your prompt response, unfortunately it does not help me, I still have a dead unit, not target for my backups and nowhere closer to a resolution.
Tried calling again and no human in sight.
What I mean that not every case is a cookie cutter solution for your process.
This specific unit was registerd by an employee that is no longer here.
Cannot setup a case if I can't register the unit (already registered), opening a case with this serial number is not allowed if I dont have the original email that it was registered under.
Cannot speak to anyone if I dont have a case.
JohnRo
Nov 16, 2016NETGEAR Employee Retired
Hello Aljst,
Please PM me some of the details of the registration, I can look it up using the serial number of the unit. Can you also give me your location and the phone number you dialed when you called in?
Looking forward to your response.
Thanks,
