Coop59
Feb 08, 2020Aspirant
VLAN Config
Hello Everyone, I am not sure if this is the right area to post, however in the home networking they don't have a category that fits what I need. I have bought a few netgear products recentl...
- Feb 11, 2020
Welcome to the community! :)
I suggest you remove the ports in VLAN 1 that you don't want to belong to VLAN 1. Since port 8 is the uplink port, it should be set as a tagged port and a member of all VLANs with a PVID = 1.
It seems that your network setup is similar to the article below. Clink on the link below and use it as your guide.
How do I set up one or more VLANs between a NETGEAR ProSAFE firewall and a smart switch?
In setting up VLANS between switches, you may use the article below as your guide:
How do I setup a VLAN trunk link between two NETGEAR switches?
DaneA
NETGEAR Community Team
DaneA
Feb 11, 2020NETGEAR Employee Retired
DaneA
