TomVgw
Dec 29, 2019Guide
Vlan on GS105Ev2 and GS116E
I have a problem with setting up a trunk between two netgear switched, a GS105Ev2 and a GS116E. The problem is I have two routers in my network, one is used for the internet connection and the other...
- Dec 30, 2019
Your 802.1q VLAN config on both switches looks 100% appropriate for the intended usage - can't see anything wrong.
Permitting the right ports are connected for the intended trunk config, I'm a little bit lost at this point. Update to the current firmware, factory reset, and reconfigure from scratch - just as a as resort attempt.
File a ticket with the Netgear support on https://my.netgear.com/ - provide all the complete insight as you have ready (or add a link to this thread).
schumaku
Dec 30, 2019Guru - Experienced User
What I'm missing in the description is a port on the GS116E connected to the TV-router configured for untagged VLAN 2, PVID 2 - similar to the GS105Ev2 port #5.
The trunk on both switches and the G105Ev2 config reads OK to me.
TomVgw
Dec 30, 2019Guide
I have attached screenshots concerning the configuration of the GS116Ev2.
The Telenet Router is the one used for the Digicorder network.
It is at port #10, vlan id 2, pvid 2, untagged.
The first digicorder (the one that works), is at port #11, vlan id 2, pvid 2, untagged.
- schumakuDec 30, 2019Guru - Experienced User
The GS116E(v1 or v2?) VLAN config looks OK to me, too. Time permitting, please show us the same views for the GS105Ev2.
Both switch firmware versions are up2date, just in case?- TomVgwDec 30, 2019Guide
Attached you will find the same views for the GS105Ev2.
The GS105Ev2 is at firmware level V1.6.0.6. I just updated the firmware level, it was at v1.6.0.4.The GS116Ev2 is at firmware level V 2.6.0.35. The current one seems to be v2.6.0.43.
The latest firmware update seems to be about changing the default password.- schumakuDec 30, 2019Guru - Experienced User
