ReadyNASUser
Dec 03, 2023Aspirant
Stripping/Tagging ISP VLAN on GS105Ev2
Hi all,
I am considering purchasing a GS105Ev2 managed switch.
I want to check it will meet my needs.
My new Internet Service Provide tags all incoming traffic with VLAN 40, and requires all traffic sent to them to also be tagged with VLAN 40.
I don't use VLANs on my internal network and have no plans to.
So I need I "strip" the VLAN tag 40 from the *incoming" traffic from the ISP, and "add" VLAN tag 40 to all *outgoing* traffic? (Not sure I'm using the correct terminology but hopefully this makes sense).
I will plug my ISP connection into Port 1, and all my other equipment in to ports 2, 3, 4 and 5.
Is it as simple as:
- Adding a new VLAN 40
- Marking port 1 as tagged
- Updating the PVID to show port 1 is part of VLAN 40
Thanks for your help
For the port (e.g. port 1) where your fiber is connected make it a trunk (tagged) port for VLAN 40 port (e.g. port 5) where you connect your router, making it an access port.
Almost as simple as you have lined out already
Updating the PVID to show port 1 is part of VLAN 40- Marking port 5 as untagged member for VLAN 40 (but not a member of any other VLAN)
- Set the PVID for port 5 to 40, ensuring all frames coming in on port 5 are associated wot the VLAN 40
Keep in mind the GS105Ev2 is a Plus configurable switch, built on an unmanaged switch core - in no aspect a managed switch.
This is why I requested a moderator moving your post to the Plus And Smart Switches Forum.
Have fun!
