ReadyNASUser
Dec 03, 2023Aspirant
Stripping/Tagging ISP VLAN on GS105Ev2
Hi all, I am considering purchasing a GS105Ev2 managed switch. I want to check it will meet my needs. My new Internet Service Provide tags all incoming traffic with VLAN 40, and requires ...
- Dec 04, 2023
For the port (e.g. port 1) where your fiber is connected make it a trunk (tagged) port for VLAN 40 port (e.g. port 5) where you connect your router, making it an access port.
Almost as simple as you have lined out already
- Adding a new VLAN 40
- Marking port 1 as tagged
Updating the PVID to show port 1 is part of VLAN 40- Marking port 5 as untagged member for VLAN 40 (but not a member of any other VLAN)
- Set the PVID for port 5 to 40, ensuring all frames coming in on port 5 are associated wot the VLAN 40
Keep in mind the GS105Ev2 is a Plus configurable switch, built on an unmanaged switch core - in no aspect a managed switch.
This is why I requested a moderator moving your post to the Plus And Smart Switches Forum.
Have fun!
schumaku
Dec 04, 2023Guru - Experienced User
Have fun!
