dibritti's avatar
dibritti
Vlan Routing to Internet GS728TPPv2
Hi all!
I really need you help with my issue,
I have one GS728TPPv2 with SW 6.0.6.3 version
And my issue is something like in this post
https://community.netgear.com/t5/Smart-Plus-and-Smart-Pro-Managed/GS728TP-VLAN-Routing-What-I-am-Missing/m-p/1409694
I follow this link "manual" and I made like is explaining but I can't reach to the gateway, and get the internet.
In vlan 100 I can get vlan 10, but I only can ping the 192.168.3.50. If I ping the gateway it gets unreacheble, so no internet.
I defined, like in the picture the defaultroute (gateway) and I also try by static
The definitions of my ethernet is fixed with the gateway 192.168.100.1, the DNS also try the gateway IP & google.
I have my PVID configuration like this, almost the same has the link above.
I turned over my firewall, following the instructions of the post because I have the same symptoms. But it's not working.
Any help I appreciate, I can't get to resolve this and the client it's starting to be upset.
Best regards
1 Reply
  • schumaku's avatar
    schumaku
    Your Internet router does have a route configured for the additional subnet, pointing to the switch?
ProSupport for Business
