lambertsonm
Apr 11, 2018Guide
VLAN Setup question
Hardware version is 1. I plan to setup 4 VLAN's on each switch as follows 1 default netgear VLAN 260 will be the managment VLAN 360 will be the normal connected device VLAN - for computers ...
- Apr 13, 2018
lambertsonm wrote:In whatever VLAN ID you like incoming untagged packets going to - just in case.
Then I should make them VLAN 360 right? not the default 1?
You define this. Can't provide a general rule. If somebody does plug a non-authorized device or an WLAN AP is reset to factory default (ie. by it's local reset button) - where do you want these? Probably not in a productive VLAN ID. Somehwere in a VLAN where you can securely check what is going mad for example I wuld suggest.
@lambertsonm wrote:
but what should I make the rest of the ports, blank, T, or U on each VLAN 1, 260, 360 and 660?
What for are the other ports used for?
The other ports will be use for computers or workstations and I am not sure how to set these ports.
Untagged for the VLAN you want the computer etc. connected to, same PVID.
Dan_Z
Apr 11, 2018NETGEAR Expert
Hi lambertsonm,
Welcome to the community!
How to config vlan,you can refter to this document.
If have any other questions,please let us know.
Thanks
- lambertsonmApr 12, 2018Guide
Well, this article does not really answer my questions. If I have multiple VLAN's going over a single port, what VLAN PVID should I use 1 or something else or doesn't it matter. Secondly, on a VLAN Say ports 1-12 are for Wi-Fi VLAN 360 and Guest Wi-Fi VLAN 660 I know that I have to tag those ports, but what should I make the rest of the ports, blank, T, or U on each VLAN 1, 260, 360 and 660?
- schumakuApr 13, 2018Guru - Experienced User
lambertsonm wrote:If I have multiple VLAN's going over a single port, what VLAN PVID should I use 1 or something else or doesn't it matter.
Yes, these are trunk ports, too. But here again, you have to configure the PVID to an ID so untagged packets - if it should happen - are tagged to.
- lambertsonmApr 13, 2018Guide
schumaku:
This answer is getting me closer to what I need to know, thank you.
