lambertsonm
Apr 11, 2018Guide
VLAN Setup question
Hardware version is 1. I plan to setup 4 VLAN's on each switch as follows 1 default netgear VLAN 260 will be the managment VLAN 360 will be the normal connected device VLAN - for computers ...
- Apr 13, 2018
lambertsonm wrote:In whatever VLAN ID you like incoming untagged packets going to - just in case.
Then I should make them VLAN 360 right? not the default 1?
You define this. Can't provide a general rule. If somebody does plug a non-authorized device or an WLAN AP is reset to factory default (ie. by it's local reset button) - where do you want these? Probably not in a productive VLAN ID. Somehwere in a VLAN where you can securely check what is going mad for example I wuld suggest.
@lambertsonm wrote:
but what should I make the rest of the ports, blank, T, or U on each VLAN 1, 260, 360 and 660?
What for are the other ports used for?
The other ports will be use for computers or workstations and I am not sure how to set these ports.
Untagged for the VLAN you want the computer etc. connected to, same PVID.
lambertsonm
Apr 13, 2018Guide
schumaku:
This answer is getting me closer to what I need to know, thank you.
If I have multiple VLAN's going over a single port, what VLAN PVID should I use 1 or something else or doesn't it matter.
schumaku
Apr 13, 2018Guru - Experienced User
