andrew_241
Jun 27, 2020Initiate
VLANs set up correctly?
Hello! I have an AT&T Uverse box attached on a dedicated VLAN (10) to a Netgear GS308T (that switch is connected to a Netgear GS105Ev2 swtich) behind a pfSense firewall, and it's unable to connec...
- Jun 28, 2020
Two Untagged VLAN on the port to the pfSense sounds wrong... one should be tagged IMHO.
schumaku
Jun 28, 2020Guru - Experienced User
andrew_241
Jun 28, 2020Initiate
That worked! I changed the pfSense connection to 'Tagged' on VLAN10. Thanks!
