tonynsx
Apr 04, 2019Luminary
Voice VLAN on smart switches
My company is thinking about getting VoIP phones. Which means our Netgear switches needs to be setup for voice VLAN. We have a mix of Netgear smart switches. Is there a guide for setting up voice ...
- Apr 05, 2019
Hi tonynsx,
Welcome to our community!
You may need to add the OUI of the VoIP so that it will automatically be assigned to its VLAN. Once the switch detects that you connected a phone which is registered in the switch, it will automatically be tagged.
Here is a document that will walk you through the setup: Voice VLAN on Smart Switches
JohnCarloV
NETGEAR Community Team
JohnC_V
Apr 05, 2019NETGEAR Employee Retired
Hi tonynsx,
JohnCarloV
