aniliri
Dec 08, 2020Aspirant
VOIP phone hanign issue
Hi , i have 300 users desk and each desk single lan drop and lan to IP phone and ip phone to users machine are connected. Earlier i was using netgear GS728 switch as core but getting high latency ...
- Jan 07, 2021
Welcome to the community! :)
Is everything working fine before? Since you have changed the switch from GS728 to a Cisco SG550X and still the same issue, kindly check the IP PBX/Sip Server or Call Manager or the Voice Gateway on your network.
Also, it would be best if you post a detailed network diagram so that other community members can make their suggestions to your concern.
DaneA
NETGEAR Community Team
DaneA
Jan 07, 2021NETGEAR Employee Retired
DaneA
- aniliriJan 26, 2021Aspirant
Thanks DaneA,
Still we are facing this issue and my all IP phone is hanged and when i restart core switch then its started working.
ISP to Firewall and Firesll to Core Switch Cisco SG550X then 5 Netgear swtich are connected, today i was getting 1ms reply but phone was hanged again i have restarted my SG550X core switch then its started working. We don't have Vlan and this is simple network and only 25 users with phones are connected.
