aniliri's avatar
aniliri
VOIP phone hanign issue
Hi , i have 300 users desk and each desk single lan drop and lan to IP phone and ip phone to users machine are connected.  Earlier i was using netgear GS728 switch as core but getting high latency ...
  • DaneA's avatar
    Jan 07, 2021
    aniliri,
    Welcome to the community! :)
    Is everything working fine before?  Since you have changed the switch from GS728 to a Cisco SG550X and still the same issue, kindly check the IP PBX/Sip Server or Call Manager or the Voice Gateway on your network.
    Also, it would be best if you post a detailed network diagram so that other community members can make their suggestions to your concern.
    DaneA
    NETGEAR Community Team
ProSupport for Business
