Gearo
Oct 24, 2022Follower
VPN access GS108PEv3
Hi! with all newer versions than GS108PEv3_V2.06.10GR, VPN access to the switch isn't possibble. GS108PEv3_V2.06.10GR is the only firmware that works with vpn. Does anybody know why?
schumaku
Oct 24, 2022Guru - Experienced User
Scratch the idea it's about VPN - the switch does not know anything about.
i suspect it's a imitation (or potentially a bug) on that simple IP stack on the embedded controller. It appears it does not honor the default gateway configured. Same eg. on the GS105PE.
