Tbelliboston
Apr 03, 2022Follower
Wac505 offline for 5 minutes every hour
I have 2 wac505 APs. Both are connected to the same Poe switch. One goes offline every hour and comes back online after 4-5 minutes. Both have firmware 9.5.5.4 They are both set to the same Sid, so...
schumaku
Apr 03, 2022Guru - Experienced User
Start with checking both WAC505 logs.
- tbelliApr 04, 2022Aspirant
Where can I find them?
- schumakuApr 04, 2022Guru - Experienced UserAmong the logs I've suggested before. Management -> Monitoring -> Logs and then [Download Detailed Logs]
A simple search in the fine documentation would certainly help - start from https://www.netgear.com/support/product/WAC505.aspx
The GS108PEv3 is a simple Web configurable switch, not. Smart Managed switch, and then not Cloud Manageable. At no point (leaving the hint from the Quick Start Guide that the Insight App can be used to discovery, find the IP and serial number for the product registration) Netgear does state the GS108PEv3 (or any other Web managed, formerly designated Plus Managed) are can be managed by any App.
