dynamiX
Nov 26, 2017Star
WAC505 no Cloud Connection
hey
suddenly i got a notification, that one access point has lost connection to the Cloud.
i've then disconnected the AP and rebootet it. after that, still no connection to the Cloud.
i then reloaded trough the app the configuration, still no luck.
the LED's are flashing white instead of green
it looks like it's connected to the internet and clients are connected to the AP but somehow it lost connections to the cloud.
what can i do? where can i send logs?
thanks
- Retired_MemberNov 27, 2017
Hi dynamiX,
We did experience some issues with Insight Cloud over the weekend but these are resolved now and your devices should show as online once again. If you are still experiencing any issues please let us know.
Regards
DavidGo
apperantly i'm not the only one. just found out that my friend who just bought them on friday has the same problem.
NETGEAR, is there a problem? are you aware of it? c'mon guys, your cloud isn't working for a whole week-end?
- Retired_Member
Hi dynamiX,
Regards
DavidGo
yes they came online a few minutes ago. thanks for the update.
however, hope this issue will not occur anymore and further outages also. because if you plan to charge customers for a service there should really be no outages, at least not 1-2 days outages...
