Tbelliboston
Apr 03, 2022Follower
Wac505 offline for 5 minutes every hour
I have 2 wac505 APs. Both are connected to the same Poe switch. One goes offline every hour and comes back online after 4-5 minutes. Both have firmware 9.5.5.4 They are both set to the same Sid, so...
tbelli
Apr 04, 2022Aspirant
Another bit of info - the poe switch is a Netgear GS108PEv3 that is not able to be managed with app
