Anonymous's avatar
Anonymous
May 25, 2022
Webinterface GS108PE v2
Hi, I got a Netgear GS108PE v2 today and I tried to access the webinterface over IP. My DHCP assigns an IP address but I can't access it. If it's not a managed switch? Why does it say DEFAULT ACCE...
  • Marc_V's avatar
    May 25, 2022
    Retired_Member
    Welcome to the Community!
    The GS108PEv2 switch does not have a Web GUI but can be managed by using the Configuration Utility that can be downloaded on the Support page. Please click here to check,
    You will use the default password to access or to configure the switch using the Utility.
    HTH
ProSupport for Business
