cybr-g
Aug 03, 2020Aspirant
What is the result of selecting "DHCP" mode for JGS524PE ?
Hi, the JGS524PE has a "DHCP" option that can be activated of disabled. But the documentation does not explain much more on the result of this activation. More precisely I would like to know ...
- Aug 03, 2020
Quickly fly over the fine documentation Gigabit Ethernet Smart Managed Plus Switches User Manual valod for Models GS105Ev2 GS105PE GS108Ev3 GS108PEv3 GS116Ev2 GS305E GS308E JGS516PE JGS524Ev2 JGS524PE starting from p.15 - it's always about the IP config assigned to the switch by it's DHCP client, served from a DHCP server on the network.
No Smart Managed Plus or Smart Managed Pro switch does contain a DHCP server for one or multiple VLANs.
schumaku
Aug 03, 2020Guru - Experienced User
cybr-g
Aug 04, 2020Aspirant
Thank you for your answer.
I was confused by the default 192.168.0.239 configuration IP.
This IP changes accordingly after network DHCP configuration or user static IP configuration.
- schumakuAug 04, 2020Guru - Experienced User
cybr-g wrote:I was confused by the default 192.168.0.239 configuration IP.
The default is DHCP, in case the DHCP request is not honoured, the switch does fall-back to the 192.168.0.239/24 address. This can be useful for an initial config of a switch purely standalone and connected to a computer.
