JimRander
Jul 09, 2016Aspirant
What means shared (combo) RJ45/SFP+ exactly at XS708T?
Dear folks, when having a look at Smart Managed Switch XS708T Document ( https://netgear.com/images/Products/Switches/SmartSwitches/10Gigabitsmartswitchseries/XS708T_XS716T_XS728T_XS748T_DS_15Apr16....
- Jul 11, 2016
Hello JimRander,
Welcome to the community!
Yes, your guess is correct they cannot be used simultaneously. So the total usable ports for the XS708T is only 8. This is by design, as they share the same switchfabric and port number. If you need all of the ports to be utilized, then you'll have to get the 24 or 48-port version of the XS series since they have dedicated ports.
Thanks,
JohnRo
Jul 14, 2016NETGEAR Employee Retired
Hi JimRander,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
