DDT3
Nov 25, 2022Aspirant
What would be the successor to GC110P
I have 3 GC110(p) switches at different places in my home. I use Netgear imsight and want to add a 4th switch the GC110P no longer is available: what would be it's most logical successor?
schumaku
Nov 25, 2022Guru - Experienced User
This depends a little bit on the features you are using on the GC110P, and what you plan for the additional switch - types of uplink ports, number of PoE ports, supported PoE standards (803.3t PoE+, 802.3bt PoE++), the types of ports Gigabit or MultiGig. Start https://www.netgear.com/business/wired/switches/smart-cloud/
