DrewTheGeek
Nov 14, 2022Follower
What's the difference?
I'm currently looking at two different switches. The GS108Ev3 plus switch and the GS308T Smart Switch. It appears that both do link aggregation but I can't seem to see what the difference is between ...
schumaku
Nov 14, 2022Guru - Experienced User
The GS108Ev3 is built on a configurable non-managed switch core, offering static LAG only, while the GS308T is built on a smarter switch core offering static LAG as well as dynamic LACP LAG.
Compare for example the S350 Series 8-Port Gigabit Ethernet Smart Switch Models GS308T and GS310TP User Manual vs. the Gigabit Ethernet Plus Switches User Manual FMI.
