Ur25v
Nov 04, 2020Aspirant
which SFP module and fiber types are compatible with the GC 110 switch
Where can I find with SFP modules and which fiber types are compatible with the GC110 range of switches?
schumaku
Nov 04, 2020Guru - Experienced User
GC110, GC110P, GC510P, GC510PP Data Sheet p.17 does describe the (supported) modules:
Optional Modules and Accessories
AGM731F-10000S SFP Transceiver 1000BASE-SX (Short range, multimode)
AGM732F-10000S SFP Transceiver 1000BASE-LX (Long range, single mode)
AGM734-10000S SFP Transceiver 1000BASE-T Copper RJ45 GBIC
marvalj
Jan 22, 2021Aspirant
However in the user manual there is a table where 10G is supported, but no sfp+ 10G is listed?
GC110P Eight PoE 10/100/1000Mbps ports
Two 10G/1G SFP+ ports
