kaischwabhosta
Apr 02, 2024Initiate
XS708E stuck at boot / fan speed max / orange PWR-LED blinking / no Uplink
Hi peeps! I need your help. Bought two second hand XS708E (v1, not v2!). One is good, the other one won't finish booting. - Power-LED ist blinking orange/amber. - Fans run at max rpm / full sp...
schumaku
Apr 02, 2024Guru - Experienced User
Hey Kai,
Officially, Netgear does not support using the (although existing internally) serial port - in the box, on the PCB. Have an eye here in case you are willing to go experimenting, instead of sending the switch to service or replacement (difficult off warranty anyway).
-Kurt.
kaischwabhosta
schumaku Thank you very much - I'd call this an ultima ratio.
