Mystified
Jan 19, 2024Aspirant
WiFi Lights Blinking Pattern
Been having WiFi Connect/Disconnect issues over the last few weeks. After recycling power, everything is fine for a random period of time in days. This happens on 2G and 5G.
Saved image, reset to factory and reloaded image, seemed okay for about a week, then the same issues.
Reset to factory and MANUALLY setup router again (port forwards etc.) Did NOT use the same SSID, again after some period of time the same ugly bear.
Wired is 100%.
Checked for firmware updates, even though I can't believe that to be the issue, but did so anyway and I have the most current flavor.
Today, I noticed that the WiFi lights are blinking rapidly and in unison 4 or 5 times then go off for about half a second. This is repeating and has been for about an hour.
Again, wired is fine, any ideas?
Sorry for the late reply. I wanted to wait and verify/confirm that it was indeed fixed.
At this point, everything is fine, have not lost any WiFI connections, the lights are displaying the same as my other Netgear R6350 which is physically right next door.
It seems it was the power brick; fortunately I had many other power bricks and managed to find one with the exact same electrical specs and checked the power connecter that goes into the router with my electronic caliper, the OD was .005 millimeters smaller, but fits tight and doesn't wiggle.
Will get a new one this week.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Troubleshoot With the LEDs.
In general, other than the patterns explained there, the LEDs and the pattern their behaviour are no use in diagnosing problems.Blinking wifi LEDS just mean traffic.
Start by trouble shooting that. Forget about the blinking LEDs.
What firmware version do you have on the device?
A number is more useful than "the latest". There may be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
If there is one it might also help if you told people the make and model number of the modem/gateway/ONT that sits between this router and the Internet. Is it, by any chance, also a router, with a set of LAN ports on the back?
I ask because a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.- MystifiedAspirant
Really???
Regardless of the firmware, the point is it's NEVER done this before.
Model:
R6230 — AC1200
To re-iterate: WiFi leds are blinking rapidly and in UNISON 4 or 5 times then go off for about half a second. NOT any kind of "normal" wifi blinking. In fact, this particular model's WiFI leds are on solid during normal operation.
To put it a different way:
Both Lights flash on/off at the same time (not independently, the same way as your eyelids blink - at the same time) for a count of 4 times, then off, then repeat. Now the pattern has changed: Both Light Blink on/off (in UNISON) 4 times, then solid for /12 second and then repeats.
This is NOT normal WiFi traffic or a connection indicator. On this particular Netgear router, WiFi lights are on solid, they do not blink even when there is traffic.
I logged into the router, disabled 2G, rebooted and the 5G led does the same thing: flash on/off for a count of 4 times, then off for about 1/2 second and repeats...
Reversed the above step with 5 G (i.e., killed it) re-enabled 2G, the same result!
As for reading the manual - every router manual that I have ever read, will not indicate the pattern that I have specified. That said, we did check the manual and the LED blinking pattern mentioned in this post is not mentioned.
Gateway has zero to do with WiFi lights blinking, but to fill in that blank, it's a Bridged Cable Modem, no AOI or double nat - even tho that has nothing to do with it as well.
We have another router attached to port 2 of 4 on the the cable modem and he works fine, i.e., his wifi lights are on solid, as they should be to indicate WiFI capabilities. No channel conflicts either.
- MystifiedAspirant
FIXED!!!
