neo998
Nov 27, 2020Aspirant
xs716T change management vlan id failed
I got a xs716t switch its F/W version is 7.0.0.20 my final goal is to make this switch's management vlan id change from 1 to 1029(which had vlan routing configured for remote access). somehow, a...
- Dec 02, 2020
There are never to many questions.
It does not make to much sense isolating the management VLAN to a dedicated network, and in the next step right away put up almost non-controlled short cut inter-VLAN routing on the switch. The idea of having a management VLAN is that you have some security appliance with firewall rules and probably additional authentication, some dedicated VPN, ... connecting to that management VLAN where in-band and out-of-band management ports, console servers, and so on where only people with physical access or strong authentication can gain access to.
neo998
Dec 02, 2020Aspirant
actually, I just want to access the management vlan via other vlans and that's why i need routing between management vlan and others.
it's alright, let me try first. i think i had already asked too many questions.
schumaku
Dec 02, 2020Guru - Experienced User
