CSeitan's avatar
CSeitan
XS716T ProSAFE 16-port 10-Gigabit - How many equipments can we connect in RJ45 10GBs : 16 or 18 ?
Hello,   I want to use a XS716T 16-port 10-Gigabit for a private network and make use of all the available 10 GBs ports to connect equipments using RJ45 copper network cables. How many ports I can ...
  • schumaku's avatar
    Nov 21, 2019
    Combo-port means you can either use the copper _or_ the SFP+ (mutually exclusive). For the XS716T this means that you can use 15T or 15F resp. 16T or 16F:
