ger24
Oct 05, 2020Tutor
xs716t routing
trying to utilize the Layer3 routing on the xs716t switch and just noticed that the "static routes" of IPv4 is 32. (from data sheet https://www.netgear.com/images/Products/Switches/SmartSwitches/10Gigabitsmartswitchseries/XS708T_XS716T_XS728T_XS748T_DS_15Apr16.pdf)
I would like to clarify confusions about routing:
does the inter-VLAN routing require the configurations on static routes on xs716t? or maybe there's no relationship between inter- VLAN routing and the static routes?
is the "static routes" primarily for allowing VLANs to link to other L3 devices(such as firewall, L3 switches)?
i guess if there are 32 VLAN IDs(ipv4) on xs716t need to reach internet(via the edge router, for example) then the "static routes"(ipv4) will run out
To answer your questions, let me share the following articles below:
VLAN Routing on Smart Switches
VLAN Routing on a NETGEAR Smart Switch
How do I set up one or more VLANs between a NETGEAR ProSAFE firewall and a smart switch?
DaneA
NETGEAR Community Team
1 Reply
- DaneANETGEAR Employee Retired
DaneA
