nsne's avatar
nsne
Virtuoso
Apr 22, 2022
XS724EM: Questions about fans/cooling
I recently purchased an XS724EM to support the increasing number of multi-gig and 10G devices we have in our home. It's replacing a D-Link 1050-28X with 4x 10G SFP+ ports and the rest gigabit, so that's my point of comparison. About 20 of the ports are used on the switch, but only around 10 of those devices are powered on consistently throughout the day.
I've noticed that the XS724EM (rackmounted, well spaced) runs quite warm in this environment, yet only one of the fans is active. The other two fans aren't even spinning. The Fan LED on the front has a distinct green glow, although that's likely light spillover from the Power LED.
Can anyone verify that this is expected behavior? And if it isn't expected behavior, are there any recommended steps and caveats for fan replacement on this model?
As a side note, I'd like to mention that it's a shame that Netgear doesn't appear to offer sensor monitoring, manual fan control (like on ReadyNAS units) or easily viewable logs via the GUI on this device.
  • schumaku's avatar
    schumaku
    All fans should be operational concurrently. Suspect a hardware.issue. Contact support via https://my.netgear.com/ - depending on your market, talk to your reseller about a DoA replacement.
    • nsne's avatar
      nsne
      Virtuoso
      Crap. I feared that was the case. I bought this on Amazon Warehouse; it was listed as just having some cosmetic damage. Even though the product is registered under my Netgear account, because of the purchase source, I have no official recourse with Netgear.
      I'm going to try to open it up and fix the fans myself in the hope that it's just the fans themselves and nothing more fundamental. Before I tuck into the unit, are there any tutorials or replacement hardware that anyone would recommend?
      • schumaku's avatar
        schumaku
        Amazon warehouse deals don't exclude warranty.
ProSupport for Business
