andrecinelli's avatar
andrecinelli
XS728T - LAG Load balancing
Hello all,   I configured a LAG to my server with 4 10G ports with LACP. My storage server is running Windows Server 2019 with NIC Teaming with LACP.   The LAG is up and running, but when I try ...
  • andrecinelli's avatar
    andrecinelli
    May 20, 2021
    You were right...
    It was some kind of intersection in the src MAC addresses.
    I made a new test by:
    - changing the switch's load balancing back to src-dst-mac.
    - changing the mac addresses of four of my servers to:
    f0-00-00-00-00-00
    f0-00-00-00-00-01
    f0-00-00-00-00-02
    f0-00-00-00-00-03
    As I have a defined number of servers that will connect to the storage, I can change their MAC addres to garantee a certain load balance in their traffic.
    But the initial question persists, WHY the web interface of the switch does not allow me to change the load balancing mode?
    Thanks,
    Andre
