RabGarcia
Dec 02, 2020Aspirant
XS728T ProSAFE 28-Port 10-Gigabit L2+ Smart Switch - PORT 9-24 is not working
Hi Everyone, I just want to ask why does my Netgear switch XS728T ports are not woking? The first problem I have encountered is clients(workstations) with 10GB PCIE card are not detecting as 10G...
schumaku
Dec 02, 2020Guru - Experienced User
Backup the config, do a factory reset just in case, and retry.
If the issue retains, there is a hardware issue. Assuming you are the original buyer, your switch is under limited lifetime warranty. Head to https://my.netgear.com , ensure the switch is registered, then -> My Support -> [Contact Support] -> Replace my defective product anf follow the guidance.
- RabGarciaDec 02, 2020Aspirant
Thank you for the quick reply.
I already reset the switch today, but the problem still occur.
You might be right that this is hardware issue. But how come last night it works well?
