WyattAkins
Apr 05, 2022Aspirant
XS748T Fan Speed Repeatedly Changing
Our switch fan speed is repeatedly changing. We have multiple switches in the same rack and this is the only one reporting the error. And our temperatures in the room are fine. Does anyone know if this is a prelude to a fan failing or if something else is going on?
| 05 Apr 2022 11:12:36 UTC-6:00%Environment-I-FANS-SPEED-CHNG: FAN'S speed level - 0 changed to level - 1. |
| 05 Apr 2022 11:01:43 UTC-6:00%Environment-I-FANS-SPEED-CHNG: FAN'S speed level - 1 changed to level - 0. |
| 05 Apr 2022 10:34:20 UTC-6:00%Environment-I-FANS-SPEED-CHNG: FAN'S speed level - 0 changed to level - 1. |
| 05 Apr 2022 10:21:47 UTC-6:00%Environment-I-FANS-SPEED-CHNG: FAN'S speed level - 1 changed to level - 0. |
| 05 Apr 2022 09:33:26 UTC-6:00%Environment-I-FANS-SPEED-CHNG: FAN'S speed level - 0 changed to level - 1. |
| 05 Apr 2022 09:23:02 UTC-6:00%Environment-I-FANS-SPEED-CHNG: FAN'S speed level - 1 changed to level - 0. |
| 05 Apr 2022 08:16:36 UTC-6:00%Environment-I-FANS-SPEED-CHNG: FAN'S speed level - 0 changed to level - 1. |
| 05 Apr 2022 07:44:10 UTC-6:00%Environment-I-FANS-SPEED-CHNG: FAN'S speed level - 1 changed to level - 0. |
| 05 Apr 2022 06:56:46 UTC-6:00%Environment-I-FANS-SPEED-CHNG: FAN'S speed level - 0 changed to level - 1. |
| 05 Apr 2022 05:44:04 UTC-6:00%Environment-I-FANS-SPEED-CHNG: FAN'S speed level - 1 changed to level - 0. |
| 05 Apr 2022 05:17:44 UTC-6:00%Environment-I-FANS-SPEED-CHNG: FAN'S speed level - 0 changed to level - 1. |
| 05 Apr 2022 03:46:18 UTC-6:00%Environment-I-FANS-SPEED-CHNG: FAN'S speed level - 1 changed to level - 0. |
| 05 Apr 2022 03:20:02 UTC-6:00%Environment-I-FANS-SPEED-CHNG: FAN'S speed level - 0 changed to level - 1. |
| 05 Apr 2022 00:49:28 UTC-6:00%Environment-I-FANS-SPEED-CHNG: FAN'S speed level - 1 changed to level - 0. |
Thanks for the help
- WyattAkinsAspirant
Hi John,
I believe we are on the latest firmware version. I could attempt to upload the 6.5.1.51 firmware and see if that fixes it.
Model Name Boot Version Software Version
XS748T 1.0.0.0 6.5.1.51 Thanks,
Wyatt
Firmware update v6.5.1.59 seemed to help. We are still getting fan speed logs but they are not constant. For instance, we received 28 events over a 14 hour period but no events occurred for a few days prior. Whereas before they were occurring every day to the extent that it blocked out other activity.
