janderson2k
Feb 23, 2022Aspirant
XS748T ProSAFE 48-Port 10-Gigabit Smart Managed Switch - IOT Issues
Good evening, so.. I have a XS748T switch and its working fine except for my IOT devices. They wont show link lights. (A YoLink hub and 2 raspberry pi's). I have tried the following: 1. New ca...
schumaku
Feb 23, 2022Guru - Experienced User
The XS748T does support 10G and 1G Ethernet links only. Most RasPi are Fast Ethernet 100 Mb/s (very few exceptions, e.g. the 4B has a GbE port, the 3B+ also has a GbE port but can handle just 300 Mb/s), can't find tech specs on that hub.
Data Sheet XS708T, XS712Tv2, XS716T, XS728T, XS748T p.6, first section
Technical Specifications XS708T XS712Tv2 XS716T XS728T XS748T
100M/1G/10G RJ-45 copper ports 8 12 16 n/a n/a
1G/10G copper ports n/a n/a n/a 24 44
janderson2k
I appreciate the feedback, but these are the 3B+ and negotiate 1Gbps on my other switch. I wonder if hard coding the pi's to 1Gbps will help...
- janderson2kFeb 23, 2022Aspirant
Well - being color blind just bit me. You were correct, its not negotiating 1Gbps. Maybe these are a diff model pie than I thought. Anywayy.. Thanks for your help!!!
