Madmumof5
Jul 16, 2023Follower
Ax1800-wax204
I have attached the router by ethernet to our hub lights are green but when use ethernet or wireless from router it says no Internet connection or private dns server cannot be connected Previousl...
schumaku
Jul 17, 2023Guru - Experienced User
Guess work only ... is the idea that the WAC104 was serving a wireless network with a wired access to the router and the rest of your LAN IP subnetwork? So configure it as an Access Point, no Wireless Repeating. The challenge is to find the WAC104 LAN IP to access the WAC104 admin page. Check your router DHCP server for the MAC address as printed on the label to locate the LAN IP.
- schumakuJul 18, 2023Guru - Experienced User
Correction: Talking of the WAX204 here of course.
