RAlfes62
Jul 15, 2023Follower
WAC104 Access Point - how to change Netbios group
I have a WAC104 Wireless Access point. Firmware 1.0.4.21. Is there a way to change the Netbios group? It shows up as "Workgroup" by default and I'd like to change it to the name I use on my network. ...
schumaku
Jul 16, 2023Guru - Experienced User
The claim this is supposed to be a NetBIOS name is at least misleading, but more likely simply wrong.
None of the WAC5xx or WAX6xx does neither broadcast an NDNS registration on changing the name nor are there the mandatory NDNS refresh cycles broadcasted. Examples attached.
Leaving alone that the modern Windows does no longer have the legacy Computer Browser Service enabled, even if the CIFS and SMB 1.0 "feature" is enabled...
MikeD1234
Jul 16, 2023NETGEAR Expert
Yes, I should have tested it. Just did it now đ.
Just tested requesting netBIOS details from my WAX630 and several other WAX APs:
WiFi:
Node IpAddress: [10.250.0.125] Scope Id: []
Host not found.
However, if I request this from my NAS, I do get a response:
WiFi:
NetBIOS Remote Machine Name Table
Name Type Status
STORAGE2 <00> UNIQUE Registered
STORAGE2 <03> UNIQUE Registered
STORAGE2 <20> UNIQUE Registered
WORKGROUP <00> GROUP Registered
WORKGROUP <1E> GROUP Registered
I just further checked it, and it seems that it's SSDP (Simple Service Discovery Protocol) that displays the name, and transmits it across, together with LLDP when it's requested by a neighboring device (i.e., switch that powers it).
Blurred out some details here đ.
RAlfes62 maybe this will help you, if you do decide to change it to a higher-end AP, that allows you to view it on the network itself.
I will discuss this with the engineering team, why it's named netBIOS, and/or, if there is confusion here, why the reference is done as it is done.
Mike
- schumakuJul 17, 2023Guru - Experienced User
Mike,
The good ol'WAC104 (received one today from a second hand market) and updated to the current does indeed publish NBNS, and answers with a full set of NetBIOS e.g. to an NBSTAT query.
Beyond the in my opinion obsolete NetBIOS workgroup announcements, it is announcing it's presence by the much more current (and IMHO useful) SSDP.
-Kurt
