Cetus's avatar
Cetus
WAX210 Management UI Rejects Password
I am a new user of a WAX210 access point.  It is ethernet connected to my switch.  It provides wifi connectivity to my devices just fine.  What it does not do is allow me access to the management UI using any method documented in the owner's manual after the initial setup.
When I attempt to access the AP UI via entering its IP address into a safari or firefox browser on my Apple Mac Studio, I get a page showing a depiction of the WAX210 device and a prompt for the device password.  When I enter the correct password, set up via the first time use, I get an "Invalid password" response.  I am absolutely certain I am entering the exact password I entered when I first set up the AP.  I am not confusing management password and internet password.  I get identical responses when I access the UI via wifi, connecting to the Management WiFi network.  My iPhone sees the Management network, connects, asks for the network password and gets a wong password response.
The firmware is 1.1.0.31 as indicated by the response screen when I first went through the initial setup.  I have done a couple of factory resets and went through the initial setup accordingly multiple times with the same result.  I've even made the management password as simple as it can be and still be accepted by the setup process - it's not possible I've mistyped.
I've even done power-off/on reboots of my workstation and iPhone.   And even pulled the pug on the AP counted to 20 and plugged it back in.  Nothing seems to work.
What, probably stupid, thing have I missed or can try?   Thanks a bunch.
  • Problem  solved.  Thanks to all who helped.  My problem was not the hyphen.  The password was accepted and worked when I introduced both a $ and % into it.  Either by itself along with the other stuff seemed not to be sufficient (or I changed something else, which I was oblivious to).
    The WAX210 now works perfectly in all modes.
  • A couple of questions that might narrow this down:
    1. When you finish the first-time setup wizard, does it actually land on the Device Status page, or does it bounce straight back to the login screen?
    2. Have you tried logging in from a private/incognito window? Safari and Firefox can autofill a saved password for that IP, which can silently replace what you type.
    If the login still fails in a private window right after a fresh factory reset and setup, that points more toward the firmware than a typing issue, so updating from 1.1.0.31 to the current release would be the next thing to try.
ProSupport for Business
