1Coops
Jan 03, 2024Aspirant
WAX220 WIFI Disconnects on Apple devices
Please help, this has been doing my nut in. WAX220 WIFI AP for some reason keeps disconnecting Apple Iphones for a minute frequently and causes calls on facetime to freeze and become unsuitable t...
zekou
Mar 13, 2024Star
After reading through all of your replies, I have done some adjustments on my side as well:
- Kept Band steering ON
- Enabled both bands 2.4GHz & 5GHz on all 4 SSIDs
- Disabled "11ax mode (for 2.4GHz only)" (OFF)
So far I have ~11h stability (based on interrupted duration of my VPN session) on my:
- Apple MacBook Pro 16-inch, 2021 (Apple M1 Max / 32GB mem / macOS Sonoma 14.4)
However, this system has also been updated from macOS Sonoma 14.2.1 to 14.4 few hours before doing all of the above tuning on WAX220 AP. The only thing related to this device that I see now in AP logs for last 11h since I cleared logs is this line periodically printed:
Wed Mar 13 08:22:52 2024 user.info devProbe: /usr/bin/devCheck> ubus send dev_probe_link '{"mac_addr": "BC:D0:74:0E:FA:B3", "link_state": "checkoffline", "if_index": "0"}'While I hope that this fixes the issue for now, I need more time testing the current setup for a few days. I will report back again.
Thank you all for following up on this thread and hope to see more feedback and hopefully Netgear engineering involvement with this issue.
Sussy May I ask, how were you able to reach support? Are you actively paying for support for this device? I was never paying for support, but I managed to talk to them in March 2023, but last few times I tried to go through the support call & chat, they would give me this case number to follow up with and call back, and when I do that, nobody picks up.
How did you manage to contact support?
b8kedziti
Apr 15, 2024Aspirant
After these adjustments are connections still solid? I am also struggling with this issue where IOS devices are constantly disconnecting from wifi and switching to cellular. For me I dont know if its this AP or IOS 17 which is riddled with WIFI issues but seeing what people are posting, the two aren't playing nice.
- zekouApr 15, 2024Star
Nothing absolutely helped in the end when it comes to WAX220 configuration.
The device is malfunctioning. It is the WAP and not your iPhone clients.
I've had WAX220 removed from service and replaced with another device since the last post.
All of the issues are gone. My devices which had most issues with disconnecting are now connected without any interrupts. Everything flows and I am hitting ~860Mbps - 1.1Gbps over WiFi for both 2.4 and 5 GHz bands , due to only 1 drywall barrier between office and WAP in the garage with distance of <10m between client devices and WAP.
- b8kedzitiApr 16, 2024Aspirant
Thank you for the reply. Its getting rather annoying to be using it like this in hopes of a F/W update to address it. I am too now looking for a replacement.
- Jimmy2024Apr 15, 2024AspirantWith 11.ax disabled and only using the 2.4ghz radio, my apple devices stay connected. Not sure if it is an apple issue or retrear. With this configuration, my WiFi network is solid.
- May 21, 2023Retired_Member
