Purple1234
Jun 17, 2022Tutor
WBC 502 Extend Wireless Network to support wireless camera
REQUIREMENT - To support wireless cameras on my WBC 502 Master (Barn) I have: Two WBC 502 set up. One as Master (Barn) - located in my barn where the internet connection is Connected to Inter...
Jun 17, 2022Guru - Experienced User
so a clarifying point.
You put the WBC in the barn is handling dhcp and that the router in the house is in access point mode.
What about the router in the barn? Is that in access point mode? or router mode?
- Purple1234Jun 17, 2022Tutor
Router in Master (Barn) is set up as a router.Internet is connected to this router.
It probably sounds a little silly to have the barn as the Master but to get an internet signal, we had to put a 20' tower on the barn. The house was not an option.
This has worked really well for years until I tried to add a wireless camera to the Barn.
When I did the install years ago, i tried making as few changes as possible.
- plemansJun 18, 2022Guru - Experienced User
I've ran into issues with broadcast internet a few times and haven't really found a good solution to it.
Are you using any dhcp on the WBC502? Thats key.
- Purple1234Jun 18, 2022Tutor
No - I tried setting my network up with as few changes to the defaults as possible.
I just double checked and both WBC 502 are getting their IP adresses from the RAX80 in the barn (Barn is connected to the WBC 502 that is acting as the MASTER).
If someone could tell me how to set up the WBC 502 using the RAX 80 to support WIFI network connectivity, assuming that this is a brand new installation right out of the box, I could take it from there.
Maybe there are certain RAX 80 and/or WBC 502 default switches that need to set.
