Sandman52
Jan 21, 2022Aspirant
Cannot Connect GS105 Switch
I am trying to connect my Netgear GS105 network switch. An ethernet cable is connected to my router/modem combo to the switch and the green lights are lit. The yellow cable is connected to my router/...
Jan 21, 2022Guru - Experienced User
can you ping from one device to the other?
do the devices get an IP address?
- Sandman52Jan 21, 2022Aspirant
Yes I can ping and they get an IP address
- plemansJan 21, 2022Guru - Experienced User
The GS105 is a simple unmanaged switch. it doesn't do any packet inspection/blocking/etc.
So if your devices are getting a ip address and respond to a ping, the switch is working.
I'd be looking at your router
I am wondering if there is a router setting that is preventing the switch from working. Is there anything particular that is a common issue with router settings that can resolve the issue?
