howell710gmail
Nov 11, 2022Aspirant
Configuring GS116PP to power Echelon EX-5s 60w via PoE
Can a 12v 5a PoE injector/splitter kit be used on the ethernet cable going to the remote exercise bike (non-PoE) to provide power? Assuming this will work because the bike is not requesting power fr...
- Nov 12, 2022
Planetechusa.com has a solution.
POE-171A-60 Single-Port Multi-Gigabit 802.3bt PoE++ Injector (60 Watts)
POE-172S Single-Port 10/100/1000Mbps Ultra PoE Splitter (12V/19V/24V)
No concern about power loss during transmission. The GS116PP will see the injector as a non-PoE device and not provide any power on the connected port. The splitter will provide the 12v 5a that I need.
Nov 11, 2022Guru - Experienced User
No. even if you could rig something to work, that switch can only supply 30 watts per port per its spec sheet.
so not only would you be risking the switch but the bike as well.
Better to just power the bike appropriately and not risk the switch and the bike with trying to rig something up to work
