howell710gmail
Nov 11, 2022Aspirant
Configuring GS116PP to power Echelon EX-5s 60w via PoE
Can a 12v 5a PoE injector/splitter kit be used on the ethernet cable going to the remote exercise bike (non-PoE) to provide power? Assuming this will work because the bike is not requesting power fr...
- Nov 12, 2022
Planetechusa.com has a solution.
POE-171A-60 Single-Port Multi-Gigabit 802.3bt PoE++ Injector (60 Watts)
POE-172S Single-Port 10/100/1000Mbps Ultra PoE Splitter (12V/19V/24V)
No concern about power loss during transmission. The GS116PP will see the injector as a non-PoE device and not provide any power on the connected port. The splitter will provide the 12v 5a that I need.
schumaku
Nov 11, 2022Guru - Experienced User
howell710gmail wrote:
Can a 12v 5a PoE injector/splitter kit ....
Technically not feasible, voltage must be higher so the cable loss (ohm'sches law) for the power transmission. There are reasons why the 802.11af and 802.11bt (for up to 90W) standard compliant systems use higher voltages, too. Of course, voltages could be multiplied, this won't be cost efficient then (highe voltage for the transmission, and lower voltage the the powered device). And no, this12v/5 idea has nothing to do with an kind of standards compliant PoE
