ronnie_to
Feb 04, 2024Follower
Daisy Chain 2 x GS108PP
Hi there, I'm trying to daisy chain 2 x GS108PP switches I own. I'm using them for larger security camera wiring job. Originally, I had 2 cables coming from the router to GS108PP, and had no issu...
ReneD
Mar 06, 2024NETGEAR Moderator
Hello ronnie_to,
And welcome to the NETGEAR Community! 🙂
This type of switches GS108PP are just passthrough switches and they are unmanaged so there is no need to configure an IP on it. Usually when you plug in the device it should work as is, your only indicator is the port led lights. You can try to use other ports or try to interchange the 2 switches and see if it will behave the same. If it results on the same which from the daisy chain the second switch does not give connectivity, then it can be a potential issue on the switch. You may want to raise a ticket and send over to Netgear Engineering team for investigation.
Have a lovely day,
Rene D
Netgear Team
